[GRASS-user] Editing dbf, problem
Kurt Springs ferret_bard at mac.com
Wed Jun 10 14:05:25 EDT 2009
The dbf file started life as an ascii file written in Textwrangler.
I converted via v.in.ascii.  The code I used was reminiscent of what I
use to use to create a site using s.in.ascii.  I couldn't find out if
the codes changed for v.in.ascii.
I have tried using various databases for my archaeological sites,
without success.  I tried following the book but I must be missing
something.  I have SQLite Browser, it seems easy to use, but I have
trouble connecting it.  (I haven't touched it in a while.)  How do you
set up the columns for easting and northing (UTM).  What about other
kinds of data (in this case the Catalog number).  Then how do you make
it display as a point vector (in this case).  The GRASS book is a
little vague, when I need a step by step approach.
Thanks for your help.
On Jun 10, 2009, at 11:36 AM, Dylan Beaudette wrote:
> On Wed, Jun 10, 2009 at 8:23 AM, Kurt Springs<ferret_bard at mac.com>
> wrote:
>> I was trying to edit one of my point vector dbf files in the file
>> PERMANENT/dbf.  I used the spreadsheet in Openoffice to adjust
>> a .dbf file.
>>  The STR_1 column originally read #1 %64 @"Cat. 64".  I needed the
>> Cat. 64
>> for a label on my map so I edited the column to read just Cat. 64.
>> Now when
>> I resize the size of the Map Display Window, everything freezes.
>> If I leave
>> the map display window alone I can work with the project a little,
>> but GRASS
>> (or WISH) unexpectedly quits, usually sooner rather than later.  I
>> tried to
>> at the #1 %64 with the quotation marks back, but this didn't help.
>> Can
>> anyone tell what the problem is and how to fix it?  Since I am
>> using Qgis to
>> do the actual displaying (and it doesn't seem to have the problem)
>> I'll be
>> fine, unless I have to adjust something in GRASS.  Then I will need
>> a back
>> up plan.
>> Thanks for any insight that people may have.
>> Kurt
> Hi Kurt,
> I (and others on the list) have encountered a variable degree of
> success when working with DBF files opened/saved by an external
> program. In some cases it works, in others the datatype (or something)
> of a column will change and all hell breaks loose. I have seen this in
> both GRASS and ESRI programs -- it just seems like the DBF file format
> is very fragile. If possible, try converting your database back-end to
> SQLite-- there are many good GUI-based tools for working on SQLite
> files, and the SQLite engine has full support for SQL. It can be a
> pain to switch between database back-ends, but I wish that I had done
> it sooner.
> Good luck,
> Dylan
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
