[GRASS-user] what is requried when import data to grass?
maven apache apachemaven0 at gmail.com
Thu Jun 11 10:10:40 EDT 2009
Hi:
I followed the doc from the web resrouce:
https://svn.wald.intevation.org/svn/pywps/tags/pywps-3.1.0/pywps/Grass.py
And I think what we are doing is similar to theirs,so I thought the
confignation of grass maybe correct for us.
2009/6/11 Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>
> maven:
> > And I know the reason of the problem now.
> Which is?
> > However as what you said,I should create a new location and mapset if
> > necessary,it does not work.
> > I create two folders nLocation/nmapset and create a wind file in the
> > nmapset dir, however when I run the grass gui,I also can not seclect
> > the new location to enter.
> Sorry, I never create manually those directories and the WIND file. I
> always use the "recommended" way, that is through GRASS.
> Read _A)_ or/ and _B)_ in:
> http://grass.osgeo.org/grass64/manuals/html64_user/helptext.html
> > It throw the error message:the selection location [nlocation ]is not
> > valide. Is the procedure I create the new location is wrong? I
> > followed the maual
> Which manual?
> Nikos
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090611/8e4f2694/attachment.html
