[GRASS-user] Question about v.generalize: nothing is removed when using douglas_reduction?
hardinej hardinej at gmail.com
Fri Jun 12 11:45:54 EDT 2009
I'm trying to use v.generalize method=douglas_reduction, but the output has
the same number of vertices as the input map and I don't know why it is not
being simplified.
In case it helps, the input map is:
v.info JR_2001SubSetLines
 | Layer:           JR_2001SubSetLines
 | Mapset:          generalize
 | Database:        /home/eric
 | Title:
 | Map scale:       1:1
 | Map format:      native
 | Name of creator: eric
 | Organization:
 | Source date:     Tue Jun  9 16:12:20 2009
 |   Type of Map:  vector (level: 2)
 |   Number of points:       0               Number of areas:      0
 |   Number of lines:        11758           Number of islands:    0
 |   Number of boundaries:   0               Number of faces:      0
 |   Number of centroids:    0               Number of kernels:    0
 |   Map is 3D:              Yes
 |   Number of dblinks:      0
 |         Projection: Lambert Conformal Conic
 |               N:        251271.999    S:        250940.025
 |               E:        913711.894    W:        913272.031
 |               B:            -1.288    T:            14.218
 |   Digitization threshold: 0
 |   Comments:
when I run
v.generalize input=JR_2001SubSetLines output=JR_2001_SSL_reduc_50
method=douglas_reduction threshold=0 reduction=50 type=line --o
I get
Number of nodes: 11758
Number of primitives: 11758
Number of points: 0
Number of areas: 0
Number of isles: 0
Number of vertices was reduced from 23516 to 23516 [100%]
Adding the -r flag to remove small lines gives the same result.
Using method=douglas without the -r flag gives the same result.
Using method=douglas with the -r flag works, but I would like to know what
I'm doing wrong and how to use the reduction feature.
Thanks,
Eric
Eric Hardin
View this message in context: http://n2.nabble.com/Question-about-v.generalize%3A-nothing-is-removed-when-using--douglas_reduction--tp3068397p3068397.html
Sent from the Grass - Users mailing list archive at Nabble.com.
