[GRASS-user] Criteria for v.clean tool=rmdangle
Dwight Needels needels at translucida.com
Sun Jun 14 01:22:40 EDT 2009
The rmdangle tool in v.clean usually behaves exactly the way I would
expect it to, but occasionally it does not.
I have a vector generated from a raster using r.thin and r.to.vect
that has numerous dangles. In the attached screenshot there are what
appear to be two dangles with lengths of ~2 and ~5 ft. The two
terminal polylines of what appears to be the core vector are 16 ft and
11 ft (27 ft combined). The pre-clean vector is gray, the cleaned
vector is red, vertices are displayed as points derived using
v.to.points.
After running v.clean tool=rmdangle thresh=30 the resulting vector (in
red) removes one of the dangles plus what appears to be the two
terminal polylines of the core  vector, while leaving the smaller
dangle attached. I tried running v.edit tool=merge or
v.build.polylines before cleaning, but got the same results.
How does v.clean decide which line segment to remove as a dangle? Is
there a way to force it to remove the line segment that leaves the
longest possible remaining vector?
My workaround has been to run v.clean repeatedly with increasing
thresholds, which I think removes the shortest line segment on each
pass.
Thanks, -Dwight
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090614/e6722e76/v.clean_rmdangle-0001.png
