[GRASS-user] problems compiling grass 7
Thu Jun 18 13:56:35 EDT 2009
Martin Landa wrote:
> >> etc/python/grass/__init__.py shouldn't contain "import lib" - it's
> >> bug.
> > Commenting "import lib" soved it.
> OK, anyway it's wrong that this line was written to __init__.py when
> compilation of Python Swig failed.
IMHO, this line shouldn't be written in either case. Code wishing to
use the SWIG bindings should explicitly use "import grass.lib". Or,
preferably, import "grass.lib.grass" etc. Loading a dozen libraries
"just in case" is a waste of resources and a potential source of
errors.
Actually, I see no reason for grass/__init__.py to exist. Code can
just import grass.script or grass.lib or both as required.
