[GRASS-user] problems compiling grass 7
G. Allegri giohappy at gmail.com
Fri Jun 19 06:34:00 EDT 2009
> yes, how to dynamically add "lib" to __all__ list when swig/python is
> build successfully?
I can't help, because I don't know the build system.
About the swig build I receive:
make[1]: shared: comando non trovato
make[1]: [_utils.so] Errore 127 (ignorato)
/usr/bin/install: impossibile eseguire stat di "_utils.so": Nessun
file o directory
make[1]: *** [/home/giova/grass/grass_trunk/dist.i686-pc-linux-gnu/etc/python/grass/lib/_utils.so]
Errore 1
make: *** [default] Errore 2
*Shared command not found*?! Isn't it a flag?
