[GRASS-user] problem creating point layer from CSV file
Tim Michelsen timmichelsen at gmx-topmail.de
Tue Jun 23 06:52:53 EDT 2009
Hello,
I tried to create a point vector from a table with coordinates:
db.in.ogr dsn=points_in.csv output=points key=myid
v.in.db --overwrite table=points x=UTM_E y=UTM_N key=myid output=points_vect
=> ERROR: x/y/z column must be integer or double
Why do I get this error?
How to I change the table column format for an imported ascii (CSV)
table in order to match integer or double?
Thanks for your help.
Kind regards,
Timmie
