[GRASS-user] v.out.ogr & kml
maven apache apachemaven0 at gmail.com
Tue Jun 23 20:55:59 EDT 2009
Hi:It seems that I have encountered the same problem,actually you should
reproject your map by yourself if you are using a earlier version.
In the later version it can reproject autoly.
If I was wrong,I hope someone can modify it .
2009/6/23 Tim Michelsen <timmichelsen at gmx-topmail.de>
> Hello,
> when exporting from a projected system to KML, is a reprojection into
> WGS84 included?
> in the manual there is:
> v.out.ogr input=random3d_hull dsn=random3d_hull.kml format=KML \
>  type=face dsco="AltitudeMode=absolute"
> Let's say I use the EPSG:2965 projection. in my works. Exporting to KML
> needs a re-projection to EPSG4326 (WGS84). On command line, this is done my
> -t_srs "EPSG:4326".
> Can this option be included into the v.out.ogr module?
> If not, one would need an additional step of re-projection on the
> commandline or witth other tools.
> Kind regards,
> Timmie
> ### example projection
> http://spatialreference.org/ref/epsg/2965/
> PROJCS["NAD83 / Indiana East (ftUS)",
>    GEOGCS["NAD83",
>        DATUM["North_American_Datum_1983",
>            SPHEROID["GRS 1980",6378137,298.257222101,
>                AUTHORITY["EPSG","7019"]],
>            AUTHORITY["EPSG","6269"]],
>        PRIMEM["Greenwich",0,
>            AUTHORITY["EPSG","8901"]],
>        UNIT["degree",0.01745329251994328,
>            AUTHORITY["EPSG","9122"]],
>        AUTHORITY["EPSG","4269"]],
>    UNIT["US survey foot",0.3048006096012192,
>        AUTHORITY["EPSG","9003"]],
>    PROJECTION["Transverse_Mercator"],
>    PARAMETER["latitude_of_origin",37.5],
>    PARAMETER["central_meridian",-85.66666666666667],
>    PARAMETER["scale_factor",0.999966667],
>    PARAMETER["false_easting",328083.333],
>    PARAMETER["false_northing",820208.3330000002],
>    AUTHORITY["EPSG","2965"],
>    AXIS["X",EAST],
>    AXIS["Y",NORTH]]
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090624/29008129/attachment.html
