[GRASS-user] Re: v.out.ogr & kml
Tim Michelsen timmichelsen at gmx-topmail.de
Wed Jun 24 08:20:38 EDT 2009
> > encountered the same problem,actually you should reproject
> > your map by yourself if you are using a earlier
> > version.In the later version it can reproject
> > autoly.
> i.e. a bug in GDAL/OGR got fixed so you need a newish version of
> that.
So this means that using gdal/ogr >= version 1.6 would automatically reproject
data exported from state plane into WGS84?
 Thanks,
Timmie
