[GRASS-user] Re: Searching EPSG code for GRASS and Continental Us, projection
Casey Vandenberg casey.vandenberg at sjgeophysics.com
Wed Jun 24 12:49:57 EDT 2009
If you can't find the appropriate EPSG code, you can always create a
custom projection using the proj 4 definitions.
I think it might look something like this:
+proj=lcc +ellps=clrk66 datum=nad27 +towgs84=7,-96,23,33,45,0,0
You can also reproject it using ogr2ogr as well if you didn't want to
use this projection.
Casey
> Message: 7
> Date: Wed, 24 Jun 2009 16:58:41 +0200
> From: reyman <reyman64 at gmail.com>
> Subject: [GRASS-user] Searching EPSG code for GRASS and Continental Us
> 	projection
> To: grass-user at lists.osgeo.org
> Message-ID:
> 	<e4d374230906240758tae6dd5bl1c3cd14dc0ca0d79 at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Hey !
> I have problem with a dbf file in old projection (old mapinfo projection) to
> convert into a grass file .. I'm searching an equivalent of this projection
> in EPSG code or with an other name ...
> The description in mapinfo.prj is :
> Conformal Projection (United States)", 3, 62, 7, -96, 23, 33, 45, 0, 0
> OR
> "Lambert Conformal Conic (Continental US)",3,62,7,-96,23,33,45,0,0
> I don't have any other information :-/
> I have this : http://spatialreference.org/ref/esri/102004/ but i think it's
> not ok ..
> If you have any information to help me about that, that's great !
> Thanks a lot !
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090624/d371827d/attachment-0001.html
