[GRASS-user] Compiling weekly source; two make errors
Seth Price seth at pricepages.org
Wed Jun 24 20:42:42 EDT 2009
I'm having two errors while compiling. The first is "no rule to make
target", so perhaps something wrong with the build system? The second is a
missing include file, which is odd because it's there. I'm not exactly
sure what to make of it. (see the last few commands in the included log)
Am I doing anything wrong?
Thanks,
Seth
$ ./configure --enable-shared --prefix=/Applications --enable-macosx-app
--with-opengl=aqua --with-freetype-includes=/usr/local/include/freetype2
&& make && sudo make install
checking host system type... i386-apple-darwin9.7.0
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... yes
creating include/config.h
include/config.h is unchanged
Copying config.status to config.status.i386-apple-darwin9.7.0
GRASS is now configured for:  i386-apple-darwin9.7.0
  Source directory:
/usr/local/grass/grass-7.0.svn_src_snapshot_2009_06_20
  Build directory:
  Installation directory:      ${prefix}/GRASS-7.0.app/Contents/MacOS
  Startup script in directory: ${exec_prefix}/bin
  C compiler:                  gcc -g -O2
  C++ compiler:
  Building shared libraries:   yes
  64bit support:               no
  OpenGL platform:             Aqua
  MacOSX application:         yes
  NVIZ:                       yes
  BLAS support:               no
  C++ support:                no
  Cairo support:              yes
  DWG support:                no
  FFMPEG support:             no
  FFTW support:               yes
  FreeType support:           yes
  GDAL support:               yes
  GEOS support:               no
  JPEG support:               yes
  LAPACK support:             no
  Large File support (LFS):   yes
  MySQL support:              no
  NLS support:                no
  ODBC support:               no
  OGR support:                yes
  OpenGL support:             yes
  PNG support:                yes
  PostgreSQL support:         no
  Python support:             no
  Readline support:           no
  SQLite support:             no
  Tcl/Tk support:             yes
  wxWidgets support:          no
  TIFF support:               yes
  X11 support:                yes
  Regex support:              yes
  POSIX thread support:       no
test -d
/usr/local/grass/grass-7.0.svn_src_snapshot_2009_06_20/dist.i386-apple-darwin9.7.0
|| mkdir -p -m 755
VERSION_NUMBER=7.0.svn
/usr/local/grass/grass-7.0.svn_src_snapshot_2009_06_20/dist.i386-apple-darwin9.7.0/tools/g.html2man.py
/usr/local/grass/grass-7.0.svn_src_snapshot_2009_06_20/dist.i386-apple-darwin9.7.0/docs/html/r.li.patchnum.html
/usr/local/grass/grass-7.0.svn_src_snapshot_2009_06_20/dist.i386-apple-darwin9.7.0/man/man1/r.li.patchnum.1
rm r.li.patchnum.tmp.html
make -C r.li.setup || echo
/usr/local/grass/grass-7.0.svn_src_snapshot_2009_06_20/raster/r.li/r.li.setup
>> /usr/local/grass/grass-7.0.svn_src_snapshot_2009_06_20/error.log
make[3]: *** No rule to make target
`/usr/local/grass/grass-7.0.svn_src_snapshot_2009_06_20/dist.i386-apple-darwin9.7.0/scripts/r.li.setup',
needed by `script'.  Stop.
make -C r.li.shape || echo
/usr/local/grass/grass-7.0.svn_src_snapshot_2009_06_20/raster/r.li/r.li.shape
test -d OBJ.i386-apple-darwin9.7.0 || mkdir -p OBJ.i386-apple-darwin9.7.0
gcc
-I/usr/local/grass/grass-7.0.svn_src_snapshot_2009_06_20/dist.i386-apple-darwin9.7.0/include
 -g -O2
  -I/usr/local/include  -D_FILE_OFFSET_BITS=64  -DPACKAGE=\"\"
-o OBJ.i386-apple-darwin9.7.0/togl.o -c togl.c
In file included from togl.c:53:
/usr/include/tkMacOSX.h:19:19: error: tkInt.h: No such file or directory
In file included from /usr/include/tkMacOSX.h:32,
                 from togl.c:53:
/usr/include/tkPlatDecls.h:107: error: syntax error before ‘*’ token
/usr/include/tkPlatDecls.h:152: error: syntax error before ‘*’ token
togl.c:54:54: error: tkMacOSXInt.h: No such file or directory
togl.c:265: error: syntax error before ‘XVisualInfo’
togl.c:265: warning: no semicolon at end of struct or union
togl.c:271: error: syntax error before ‘}’ token
togl.c:310: error: invalid use of incomplete typedef ‘Togl’
togl.c:313: error: invalid use of incomplete typedef ‘Togl’
GRASS GIS compilation log
Started compilation: Wed Jun 24 17:35:32 MDT 2009
Errors in:
/usr/local/grass/grass-7.0.svn_src_snapshot_2009_06_20/visualization/nviz
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Wed Jun 24 17:43:24 MDT 2009
make: *** [default] Error 1
$ locate tkMacOSX.h
/Developer/SDKs/MacOSX10.4u.sdk/System/Library/Frameworks/Tk.framework/Versions/8.4/Headers/tkMacOSX.h
/Developer/SDKs/MacOSX10.4u.sdk/usr/include/tkMacOSX.h
/Developer/SDKs/MacOSX10.5.sdk/System/Library/Frameworks/Tk.framework/Versions/8.4/Headers/tkMacOSX.h
/Developer/SDKs/MacOSX10.5.sdk/usr/include/tkMacOSX.h
$ ls -l /usr/include/tkMacOSX.h
lrwxr-xr-x  1 root  wheel  76 Apr 10 16:51 /usr/include/tkMacOSX.h ->
../../System/Library/Frameworks/Tk.framework/Versions/8.4/Headers/tkMacOSX.h
$ locate tkInt.h
/Developer/SDKs/MacOSX10.5.sdk/System/Library/Frameworks/Tk.framework/Versions/8.4/Headers/tk-private/tkInt.h
