[GRASS-user] r.roughness again
Manuel Seeger manuel.seeger at wur.nl
Mon Jun 29 06:06:00 EDT 2009
Hello all,
we shifted now to my computer, running under jaunty, grass 6.4.
Trying r.roughness we have still some problems:
GRASS 6.4.0svn (Roughness_m):~/grass-addons > ./r.roughness
map=DGM.rough.m grid=3
[: 221: 1: unexpected operator
Scanning input for column types...
Maximum input row length: 0
Maximum number of columns: 0
Minimum number of columns: -1
ERROR: x column number > minimum last column number
       (incorrect field separator?)
ERROR: Vector map <TMP_vect> not found
ERROR: Raster map <DGM.rough.m.roughness.3> not found
ERROR: Raster map <DGM.rough.m.roughness.3> not found in current mapset
Removing vector <TMP_vect>
WARNING: Vector map <TMP_vect> not found
WARNING: <TMP_vect> nothing removed
Surface roughness map created and named [DGM.rough.m.roughness.3].
Consider renaming.
Done.
Logically, after so many errors, there's no map crated.
Whats the problem? Can anybody help?
Thanks
Manuel
__________________________________________________________
Dr. Manuel Seeger
Dept. of Land Degradation and Development
Wageningen University & Researchcenter
Postal address:
P.O. Box 47, 6700 AA Wageningen, The Netherlands
Visitors address:
Atlas building, Droevendaalsesteeg 4, 6708 PB, room B415
phone:	+ 31 317 486617
fax:	+ 31 317 419000.
