[GRASS-user] Making contours from a table of x,y,z coordinates
    Dr Barry MacEvoy
    b.macevoy at imperial.ac.uk
    Mon Mar  2 09:49:38 EST 2009
Folks,
Firstly, I've only just started to use GRASS, so I hope this isn't
too painful to read for experienced users.
I've got a csv table of data with x,y,z coordinates representing
around 40 points in 3D space. z is the dependent variable (in fact,
it's the percentage of carbon found in soil samples at various
locations).
I'd like to make some contour lines for the z data, so I've carried
out the following steps:
1.Convert .csv file to a vector map
v.in.ascii -z
input=/Users/bcmac/Desktop/test/final_data_for_contours.csv
output=vector_xyz format=point fs=, skip=0 x=1 y=2 z=3 cat=1
2.Match region to vector map
g.region vect=vector_xyz at test
3.Check that region is sensible
g.region -p
4.Create an interpolated raster surface from the vector map
v.surf.idw --overwrite input=vector_xyz at test output=raster npoints=12
layer=0
5.Create vector map of specified contours from raster map layer
r.contour --overwrite input=raster at test output=contours
minlevel=0 maxlevel=90 step=5
6.Export vector map as .dxf
v.out.dxf --overwrite input=contours at sophie
output=/Users/bcmac/Desktop/test/final.dxf
But when I look at the contours, they don't seem to follow the
original data - which I've plotted up in ArcGIS in the (x,y) plane
with the symbol size proportional to the value of z.
Have I gone horribly wrong? If so, where?
Thanks in advance for your help,
Barry.
Dr Barry MacEvoy
High Energy Physics Group
Imperial College London
Blackett Laboratory
Prince Consort Road
LONDON SW7 2BW
England
T: +44 20 7594 7802
F: +44 20 7823 8830
M: 07767 323871
http://www.hep.ph.ic.ac.uk/cms/people/based_at_imperial.html
http://www.hep.ph.ic.ac.uk/e-science/people/macevoy.html
