[GRASS-user] v.to.rast "Converted points/lines: 0 of 47763"
achim ak7 at jupiter.uni-freiburg.de
Tue Mar 3 06:11:52 EST 2009
Thanks Hamish,
but I do have cats. I did v.clean and I tried with v.category, too. But
it doesn't help.
Maybe my cats addressing the nodes???
achim
Hamish schrieb:
> achim wrote:
>> today another question.
>> My problem:
>> I converted boundaries from an area vmap to lines via
>> v.type
>> v.type input=gitter at achim output=gitter_lines
>> type=boundary,line --o
>> Now I want to convert these lines to raster-cells via:
>> v.to.rast --overwrite input=gitter_lines at achim
>> output=gitter_lines
>> use=cat type=line
>> but nothing converts!
>> Loading data...
>> Pass 1 of 2:
>> Reading features...
>> Schreibe Rasterkarte...
>> Pass 2 of 2:
>> Converted areas: 0 of 0
>> v.to.rast komplett.
>> What am I doing wrong?
> boundaries typically do not have a category value (e.g. a boundary between
> two fields: which farmer owns the boundary?), but sometimes can (e.g. if
> boundary is also a road)
> only items with category are processed by most vector modules (they loop
> from the first cat to the last cat). So run v.category to add cats to
> your lines and then it should work.
> there is a (short) word about this in the vectorintro help file.
> Hamish
