[GRASS-user] importing an e00 file grass6.2
Markus Metz
markus.metz.giswork at googlemail.com
Thu Mar 5 03:45:00 EST 2009
Janet Choate wrote:
> Hello grass user community,
> I am trying to import an e00 file into grass6.2.2. In older versions
> of grass, I was able to use m.in.e00, which is no longer
> available with grass6 versions. I see that I should be able to use
> v.in.e00 with grass6.2.2. However, I get the following error:
> command used: v.in.e00 file=ms02714.e00 type=area
AFAIK, e00 files can also contain raster grids. If there is really a
raster in there, there is a tool called import71 running on Windows only
which can get both coverages and grids out of an e00 file. After that
r.in.gdal should work. Just an idea.
