[GRASS-user] How update vector layers?
Thybério Luna Freire
thyberio at gmail.com
Sat Mar 7 14:03:05 EST 2009
Hi Vincent,
I've tried the following command:
v.patch -ae input=sugarcane,sugarcane_update output=sugarcane --o
it returns:
ERROR: Output vector map <sugarcane> is used as input
I'm using the -e and -a flags and overwriting the old vector layer, but the
message is the same.
I'm doing anything wrong?
Both vector maps have exactly the same columns and there aren't identical
attributes:
Cat (integer)
Cane_id(Integer)
thanks,
Thyberio
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090307/223eaa93/attachment.html
