[GRASS-user] reclass problem
Markus Neteler
neteler at osgeo.org
Tue Mar 10 06:34:12 EDT 2009
On Tue, Mar 10, 2009 at 10:59 AM, ambrish dhaka <ambijat at hotmail.com> wrote:
> Hi! all,
> I wish to classify the landuse from the landsat data of 1989. I created a
> 531 (rgb) composite and the features were quite noticeable. The
> relcassification part I tried to use pixel value for creating classes for eg
> 9320 thru 10367 = 1 semiurban etc.
> The problem is that there are other types of areas such as uncultivated
> fields that also get classed into areas such as semiurban. How to deal with
> this.
> And also is there any method to create polygon out of textures. The urban
> areas are quite noticeable by their texture or arrangement of pixel values.
> Is there any floating window formula that can use std dev to create such
> surfaces, I am not sure.
Two quick suggestions:
- mask out zones which aren't of interest (r.mask)
- use a classifier like i.maxlik or better i.smap to perform a statistical
assignment of pixel values to desired classes.
For an overview, see
http://grass.osgeo.org/wiki/Image_processing#Image_classification
Markus
