[GRASS-user] Network analysis: Linear reference system (LRS) - on windows
Moritz Lennert mlennert at club.worldonline.be
Fri Mar 13 07:05:38 EDT 2009
On 13/03/09 10:28, Helmut Kudrnovsky wrote:
>> On 13/03/09 01:20, Helmut Kudrnovsky wrote:
>>> hi,
>>> i'm trying the example for  Network analysis: Linear reference system (LRS)
>>> from
>>> http://www.grassbook.org/examples3rd_chapter6.php
>>> for the step
>>>  # add column to link the route with the bus stop
>>> v.db.addtable route1 col="lid integer" (just copied from the website above)
>> Could you tell us how/where you enter this command ?
>> Have you tried using the GUI window via the menu ?
>> Moritz
> hi moritz,
> i copied the command from the website in the wx-gui-commandline.
> if i enter the parameters in the v.db.addtable-gui, i get the same error messages.
> maybe related to http://trac.osgeo.org/grass/ticket/488
Yes, there seems to be some problem with handling quoting in the GUI
command line... Which GUI are you using ?
Moritz
