[GRASS-user] problem about import of shp file
Markus Metz markus.metz.giswork at googlemail.com
Wed Mar 18 06:31:08 EDT 2009
Natsuko YOSHIFUJI wrote:
> 3) v.in.ogr dsn=lu2543s.shp output=lu2543s -o
> Succeeded, but had an error message.
> Seems to failed to Import of area and isles...???
I forgot, it may help to close all other applications to get as much
memory as possible. BTW, the procedure to break polygons should use
about 20% less memory in grass65 than in grass64 and something between
20% and 40% less memory in grass7 than in grass64.
