[GRASS-user] problem about import of shp file
Natsuko YOSHIFUJI natsuko.yoshifuji at gmail.com
Wed Mar 18 10:46:52 EDT 2009
On 2009/03/18, at 22:07, Markus Neteler wrote:
> On Wed, Mar 18, 2009 at 1:29 PM, Markus Metz
> <markus.metz.giswork at googlemail.com> wrote:
>> Natsuko YOSHIFUJI wrote:
>>> Where can I get grass-6.5 and grass7?
>> grass-6.5 and grass-7 are only available as source code via svn.
> If desired, I can set up cronjobs to generate also the grass-6.5 and
> grass-7 binaries. For grass-7, there is the problem that I don't
> manage
> to compile CAIRO >= 1.5.8 on Fedora FC4 which is used on
> grass.osgeo.org.
> Help (i.e., 32bit RPM) welcome.
Thank you very very much!!!!!
I hope binaries of grass-6.5 or grass7.
I am not so familiar with PC, so I try to tell you my PC environment
anyway.
There are 3 type of PC around me.
If possible, binaries for Mac is preferable because mac has the
biggest memory,
but binaries for linux and windows+cygwin is available.
PC1 (note pc)
Windows XP professional + cygwin
1.5GB RAM
Grass - 6.2.3 is already installed
* I used this pc to import shp file and failed with an error message
<n failed "node.c", line48 Aborted (core dumped)>.
* Grass on this pc reported that lu2543s.shp is tmerc, but it may not
be true...
PC2
Fedora Core 5
622MB RAM
Grass-6.2.2 is already installed
* import of shp file was forced to stop, probably because of shortage
of memory...?
PC1
Mac OS 10.5.6
2.1GHz Intel Core 2 Duo
3GB 667 MHz DDR2 SDRAM
Grass-6.3 is already installed
* import of shp file was failed with an error message as follows:
Break polygons:
Registering points ... 17107648v.in.ogr(1388) malloc: ***
mmap(size=624242688) failed (error code=12)
*** error: can't allocate region
*** set a breakpoint in malloc_error_break to debug
ERROR: G_realloc: out of memory
With best regards,
Natsuko YOSHIFUJI
