[GRASS-user] EPSG 3035
Laura Poggio laura.poggio at gmail.com
Wed Mar 25 11:57:38 EDT 2009
Dear all,
I am starting to use GRASS and I am trying to set up a location with the
LAEA ETRS89 projection (EPSG 3035).
First I set up the location using the EPSG code and the I tried to import a
geotiff with the same projection (created with gdal_translate). However I
got the error "Projection of dataset does not appear to match current
location".
Then I set up the location using the georeferenced file itself, I tried to
import the same file and I got the same error.
I can manage to import the file using the -o option and over-riding
projection check, but I would like to understand and possible solve the
problem.
I am using GRASS63 under linux.
Thank you very much in advance
Laura
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090325/440f3497/attachment.html
