[GRASS-user] EPSG 3035
Moritz Lennert mlennert at club.worldonline.be
Thu Mar 26 05:24:57 EDT 2009
On 26/03/09 10:03, Laura Poggio wrote:
> The output of g.proj - p
> -PROJ_INFO-------------------------------------------------
> datum      : etrs89
> ellps      : grs80
> -PROJ_UNITS------------------------------------------------
> unit       : metre
> units      : metres
> meters     : 1
> That looks better
No, you should have something like this:
GRASS 7.0.svn (test3035):~ > g.proj -p
name       : Lambert Azimuthal Equal Area
proj       : laea
datum      : etrs89
ellps      : grs80
lat_0      : 52
lon_0      : 10
x_0        : 4321000
y_0        : 3210000
no_defs    : defined
unit       : metre
units      : metres
meters     : 1
GRASS 7.0.svn (test3035):~ > g.proj -w
PROJCS["Lambert Azimuthal Equal Area",
     GEOGCS["grs80",
         DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433]],
     PROJECTION["Lambert_Azimuthal_Equal_Area"],
     PARAMETER["latitude_of_center",52],
     PARAMETER["longitude_of_center",10],
     PARAMETER["false_easting",4321000],
     PARAMETER["false_northing",3210000],
     UNIT["metre",1]]
How did you create this location ?
Moritz
