[GRASS-user] creat a temp workplace
Jachym Cepicky jachym.cepicky at gmail.com
Mon Mar 30 02:17:07 EDT 2009
hi,
On Fri, Mar 27, 2009 at 03:33:09PM +0800, apachemaven wrote:
> And in the step 2, I want to creat a temp location and mapset,beacuse my current location is the spanish example data...
> My god,I am crazying@@!
basically, any location can be considered as "temp", because of after
deleting the whole directory, it is gone (uninstalled).
if you want to create temp location in a batch script, just prepare some
    template location (with PERMANENT mapset and DEFULT_WIND and other
    files)
than you can just copy this template under new name and so the temporary
location is created.
if you set the GRASS_BATCH_JOB env. variable, (shell script to be
processed as batch job), the script will be performed automatically.
jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/JachymCepicky.pgp
Key fingerprint: 0C6D 0EAE 76BD 506C F299  ED8A C8AB 74B8 08D4 E08F
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090330/6eff5ff5/attachment.bin
