[GRASS-user] v.net.path weight & co
Hamish hamish_b at yahoo.com
Fri May 8 05:52:58 EDT 2009
Stefano wrote:
> i've some problem with v.net.path
> now, if i specify the length of the path as weight i
> should receive the same path, right? but this doesn't
> work.
don't quote me on this, but maybe try the inverse length?
ie make a column which is SQL magic "max(length column) - this_line_length"
and use that as the cost.
e.g. see the help page example with speed limits.
I may have it backwards,
Hamish
