[GRASS-user] r.series g.mlist unhappy together
saewan koh saewan at gmail.com
Wed May 20 16:42:26 EDT 2009
Hi Markus and Martin,
Yes the solution for the day was indeed the solution i was looking
for.  As a GRASS noobie it never occurred to me that the wxGUI might
treat some of the commands differently!
Thank you (everyone)!
(what a relief : )
Saewan
On 20-May-09, at 2:18 PM, Markus Neteler wrote:
> On Wed, May 20, 2009 at 9:58 PM, saewan koh <saewan at gmail.com> wrote:
>> Hi Markus,
>> On 20-May-09, at 1:48 PM, Markus Neteler wrote:
>> Hi Saewan,
>> On Wed, May 20, 2009 at 8:51 PM, saewan koh <saewan at gmail.com> wrote:
>> The last weird thing i just discovered is that when i use g.mlist
>> on its own
>>  - it will not run if i use quotations as in g.mlist rast
>> pat="SmrDDT0Tot*"
>> What happens exactly?
>> When i run
>> g.mlist pattern="*1986*dd5s"
>> I get the following output.
>> (Wed May 20 13:49:57 2009) Command finished (0 sec)
>> If i run g.mlist pattern=*1986*dd5s
>> 1986_4_12_4_18_dd5s
>> 1986_4_19_4_25_dd5s
>> 1986_4_26_5_2_dd5s
>> 1986_4_5_4_11_dd5s
>> etc.
> Bingo I got it thanks to Martin's comment: you use (did you mention?)
> the wxGUI command line which is currently "eating" the quotes.
> A known bug which requires some work to be fixed.
> Solution for today: launch the commands in the real terminal.
> Markus
