[GRASS-user] Re: IN: raster-flow-direction OUT:vector-network? (achim)
achim ak7 at jupiter.uni-freiburg.de
Wed May 20 19:22:25 EDT 2009
Thanks for reply,
but thats not exactly what I am searching for. I can not to use the
accumulation values, because
i) I want to figure out the watersheds on parts of the network
(beginning from certain points of the river network to separate some
basins on different levels; I already wrote a script to do it with the
direction raster map, but its slow and it does not allow me to do ii)
ii) I am going to do some statistics on stream lengths /accumulations on
network parts
iii) I need to separate parallel flowing streams from each other which
does not work on my current resolution
I start with pre-produced flow direction, accumulation...
Any workaround idea or scripting tips?
cheers again,
achim
PS: illustration on
http://lists.osgeo.org/pipermail/grass-user/attachments/20090520/6198f353/rasterflow-to-network.png
PPS:
> r.mapcalc 'log_accumulation=log(abs(accumulation)+1)'
QUESTION:
why abs? accumulation values should be positive!?
Margherita Di Leo schrieb:
> Hi Achim,
> i usually produce the river network starting from the flow accumulation,
> not from the flow direction. If you have a raster elevation map you can
> get it using r.watershed.
> Then, i make as follows:
> r.mapcalc 'inf_river=if(log_accumulation>6)'
> 6 is a treshold value for the log_accumulation, it is a good value for
> me but you maybe can try other values. It produces a binary map.
> Then:
> Raster -> Transform features -> Thin linear features to reduce at 1pixel
> the lines of the binary raster inf_river and create the new file in_river.
> Finally, with r.to.vect you can transform the raster in_river in a
> vector map.
> Hope this helps
> Margherita
>> Message: 8
>> Date: Wed, 20 May 2009 16:45:56 +0200
>> From: achim <ak7 at jupiter.uni-freiburg.de>
>> Subject: [GRASS-user] IN: raster-flow-direction OUT:vector-network?
>> To: grass-user <grass-user at lists.osgeo.org>
>> Message-ID: <4A1417A4.3040701 at jupiter.uni-freiburg.de>
>> Content-Type: text/plain; charset="iso-8859-15"
>> Hello,
>> I am searching for a good idea to convert a raster-flow-direction map
>> into a vector-network map.
>> Probably I will have to write a script. If it is possible at all...
>> In case of writing a script it mean to me: how to produce a line within
>> r.mapcalc?
>> Has anyone a hint?
>> Cheers,
>> achim
>> PS:for illustration I attached a little picture
>> -------------- next part --------------
>> A non-text attachment was scrubbed...
>> Type: image/png
>> Desc: not available
>> Url :
>> grass-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> End of grass-user Digest, Vol 37, Issue 35
