[GRASS-user] Can this be done in GRASS
Hamish hamish_b at yahoo.com
Fri May 22 22:54:18 EDT 2009
Bill wrote:
> Hi, the attached 3D image I believe was generated by
> software. I was wondering is someone could tell me if there
> is a way to create something similar with GRASS,
> out of shapefiles (or do I need something more, like an
> aerial photo?)
Mark wrote:
> It looks like a relief map.
>  Done by building a DEM and adding shadded relief, or
> draping an aerial over the DEM.  NVIZ in GRASS has some
> neat stuff.
right; i.e. either with:
  r.shaded.relief + d.shadedmap for two raster maps
    (e.g. DEM and satellite image), or opacity overlay in GUIs
or
  r.shaded.relief + multiple d.vect overlays (shapefiles)
    using opacity slider in the GUIs. (or convert vector maps
    to raster with v.to.rast then with d.shadedmap as above.
or
  nviz elevation=dem color=satellite_image
you can use r.in.wms or more simply the r.in.onearth module
from wiki addons to pull in e.g. LANDSAT imagery from NASA.
some of the examples here give command scripts:
  http://grass.osgeo.org/screenshots/raster.php
  http://grass.osgeo.org/screenshots/viz.php
Hamish
