[GRASS-user] Error building Grass 7: diglib
Eric Patton epatton at nrcan.gc.ca
Wed May 27 09:33:32 EDT 2009
I was building a fresh checkout of Grass 7 from svn this morning,
revision 37538, and ran across the following error:
$ cat error.log
iGRASS GIS compilation log
Started compilation: Wed May 27 10:12:57 ADT 2009
Errors in:
/usr/local/grass_trunk/lib/vector/diglib
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Wed May 27 10:19:23 ADT 2009
Then I changed to lib/vector/diglib, make clean, and make:
$ make
<snip>
make[1]: Entering directory `/usr/local/grass_trunk/lib/vector/diglib'
echo "==============TEST============="
gcc -I/usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/include  -g -O2   -fPIC -I/usr/local/include  -D_FILE_OFFSET_BITS=64 -L/usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/lib -Wl,--export-dynamic -Wl,-rpath-link,/usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/lib   -I/usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/include  -o OBJ.x86_64-unknown-linux-gnu/test test.c -lgrass_dig2 -lgrass_gis -lgrass_datetime -lz     -lgrass_rtree  -lgrass_rtree \
				-lgrass_gis -lgrass_datetime -lz     -lgrass_datetime -lm  -lz
cd OBJ.x86_64-unknown-linux-gnu; LD_LIBRARY_PATH="/usr/local/lib:/usr/lib:/usr/local/grass-7.0.svn/lib:/usr/local/grass-6.5.svn/lib:/usr/local/grass-6.4.svn/lib:/usr/local/grass-6.3.1/lib:/usr/local/IVS/lib::/usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/lib" ./test; diff ./test.tmp ../test64.ok
./test: symbol lookup error: ./test: undefined symbol: dig__fwrite_port_O
Binary files ./test.tmp and ../test64.ok differ
make[1]: *** [OBJ.x86_64-unknown-linux-gnu/test] Error 2
make[1]: Leaving directory `/usr/local/grass_trunk/lib/vector/diglib'
make: *** [default] Error 2
A symbol lookup error on  dig__fwrite_port_O; and ideas on this one?
Eric Patton
