[GRASS-user] division in v.db.update or sql expression + db.execute results always "zero"
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Thu May 28 06:55:52 EDT 2009
Nikos:
> #using grass6_dev, compiled some weeks ago
> # sql expression
> echo "UPDATE sample_1_grid_points SET exprtest=burned_pix / 10" |
> db.execute
> and I always get a "0". Multiplication, addition and subtraction work
> fine but division seems not.
Not always. The problem is that the decimals are not printed so I see
only the leading 0 and the ".xxx" is missing.
For example:
* column "burned_pix" has min=1, max=281
* division by 10 gives numbers from 0 to 28
* division by 100 gives numbers from 0 to 2
successively, division with a denominator > nominator _prints-out_ zero
as a result.
Before testing with spearfish...
> ...Is this a bug?
Nikos
> [1] http://n2.nabble.com/Fwd%
> 3A-calculate-values-of-an-attribute-table-column-tc1885693.html#a1885698
