[GRASS-user] Compile grass65 svn-> QGIS memory access error
achim ak7 at jupiter.uni-freiburg.de
Thu May 28 15:12:55 EDT 2009
Hi again,
its not --with-64bit, but --enable-64bit for 64bit-support
Moreover: WHAT THE ... Now my QGIS does not start anymore! What have I
done? Running it give a Speicherzugriffsfehler (memory access error).
Maybe I should not have tried...
Now I switched on and off the wx-stuff I installed. Reinstalled qgis1.1,
installed qgis1.0 (same error).
Should not be so difficult, hu?
Thanks again,
Achim
PS: wx.Python error still exists, but I can use the old gui as well.
achim schrieb:
> Hello,
> thanks, but that does not seem to be the (my) mistake.
> I did a new checkout and also checked, if any dev-packages are missing.
> I hope not; I have installed:
> wxWidgets-devel
> (wxWidgets)
> wxSQLite3-devel
> wxGTK-devel
> (python-wxGTK)
> libwxsvg-devel
> anything missing?
> I also put the explicit path to to configure command
> --with-python=/usr/bin/python-config \
> CFLAGS="-O3 -msse3 -march=core2 -Wall" LDFLAGS="-s" ./configure \
>       --with-64bit \
>       --with-libs=/usr/lib64 \
>       --with-fftw \
>       --with-cxx \
>       --with-sqlite \
>       --with-postgres \
>       --with-postgres-libs=/usr/include/pgsql/libpq \
>       --with-postgres-includes=/usr/include/pgsql \
>       --with-freetype \
>       --with-freetype-includes=/usr/include/freetype2 \
>       --with-motif \
>       --with-proj-share=/usr/share/proj \
>       --with-geos \
>       --with-wxwidgets=/usr/bin/wx-config
> Achim
> Jan Trochta schrieb:
>> HI, I think hat you don't have installed wxWidgets-devel or another -dev
>> package from WX
>> Jan Trochta
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
