[GRASS-user] error importing postgresql db
Hamish hamish_b at yahoo.com
Sun May 31 19:33:04 EDT 2009
> Seb:
> > I tried importing a PostgreSQL table (a view) using
> v.in.ogr.  However the module failed
> > The warning about the sex column is harmless since it is just a custom
> > type and the 255 limit is fine here.  The parsing error with time column
> > seems to have prevented the vector from building properly though.  The
> > same error occurs when doing it with v.in.db.  The view and the
> > underlying tables show no problems in Postgresql.
Nikos:
> Not sure if this is a conflict with SQL commands, but you could try to
> _feed_ new names for your columns by using the "cname=" paramater of
> "v.in.ogr" and see what happens?
"time" is a reserved SQL keyword, and column names are not someway quoted,
so it conflicts.
see:  https://trac.osgeo.org/grass/ticket/578
Hamish
