[GRASS-user] Re: CTRL-C behaviour
Νίκος Νίκος
Mon Nov 2 21:58:37 EST 2009
(Apologies for sorting your pots :-)
On Tue, Nov 3, 2009 at 2:25 PM, Joel Pitt <joel.pitt at gmail.com> wrote:
> > Hi,
> > I've noticed that the my current check out from the VCS now binds
> > CTRL-C to quitting the shell.
> > Is there anyway to disable this? It's highly frustrating when I type
> > CTRL-C to end a process, but sometimes the process ends before I push
> > the keys - leading to an inadvertent session end and me having to set
> > up my work space again.
> > CTRL-d is the usual key combo for a shell logout, which works just fine.
On Tue, 2009-11-03 at 15:06 +1300, Joel Pitt wrote:
> I've also noticed that I use CTRL-C to abort a command line and give
> me a clean one (yet still leave what I typed previously on the
> screen).
> For a system that has it's roots in the command line, I feel this
> change has had a significant impact on usability.
Maybe it's the same I described in my post "Access mapsets out of grass
(small problem when launching a grass session)" [1]?
I use very frequently Ctrl+C to just get a new line.
Nikos
[1] http://www.mail-archive.com/grass-user@lists.osgeo.org/msg10874.html
