[GRASS-user] FFTW framework problem
William Kyngesburye woklist at kyngchaos.com
Tue Nov 3 16:02:14 EST 2009
The Leopard GRASS build still requires the FFTW framework, which is
now in my download archives.  The next version, whenever that happens,
will be like the Snow Leopard build with an internal FFTW.
On Nov 3, 2009, at 2:48 PM, Richard Chirgwin wrote:
> Hi,
> Having had to rebuild a MacBook Pro, I've installed William K's
> 6.4.0RC5 build of Grass-GIS.
> I'm running it under OS X 10.5.8.
> Even though I have installed the FreeType framework (v2.3.11-1),
> ps.map crashes reporting a problem with the framework:
>> dyld: Library not loaded: /Library/Frameworks/FFTW3.framework/
>> Versions/3/FFTW3
>>  Referenced from: /Applications/GRASS-6.4.app/Contents/MacOS/lib/
>> libgrass_gmath.dylib
>>  Reason: image not found
>> Trace/BPT trap
> The first time it happened, I did the following:
> - Delete the Grass-GIS application
> - Trash the installer receipt
> - Reinstall the framework
> - Reinstall Grass-GIS and the Grass-GDAL plugin
> The problem still occurs. Any suggestions?
> Richard Chirgwin
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
