[GRASS-user] GUI startup question
Richard Chirgwin rchirgwin at ozemail.com.au
Sun Nov 8 01:39:21 EST 2009
Hamish,
Thanks, I will probably use the d.m GUI.
Interestingly there's something in the setup (6.4RC5 on OSX); when I use:
g.gui oldtcltk
I get the same result as if I use d.m ... so the old GUI really is dead
I suppose.
Cheers,
RC
Hamish wrote:
> for xmons (no GUI), GRASS_WIDTH and GRASS_HEIGHT + d.mon.
> see "g.manual variables" for more info.
> if in a rush you might also try the old gis.m GUI or the surprisingly
> fresh d.m GUI. (Mac and Li*nux only)
> Hamish
> --- On Fri, 11/6/09, Richard Chirgwin <rchirgwin at ozemail.com.au> wrote:
>> From: Richard Chirgwin <rchirgwin at ozemail.com.au>
>> Subject: [GRASS-user] GUI startup question
>> To: grass-user at lists.osgeo.org
>> Date: Friday, November 6, 2009, 7:30 PM
>> Hi,
>> I'm seeing an issue with Grass-6.4RC5 under OSX 10.5, with
>> the GUI sometimes hanging when I resize the display.
>> I have something that I need to process quickly next week,
>> so I'd like to adjust the display size on startup to my
>> preferred dimensions. I can try and work out what's wrong
>> later ...
>> The question is, where is the variable for setting the map
>> display size?
>> Cheers,
>> Richard Chirgwin
>> grass-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-user
