[GRASS-user] New version of r.stream.order
MS mseibel at gmail.com
Mon Nov 9 11:56:22 EST 2009
This sounds great. Thanks for the contribution.
I have been wanting to use these stream analysis tools, but ran into a
packaging problem under kubuntu, and am still trying to sort it out. I
seem to recall it having to do with the grass-dev package in ubuntugis
repo.
Mark
On Nov 9, 2009, at 9:47 AM, Jarosław Jasiewicz <jarekj at amu.edu.pl>
wrote:
> Hi all!
> I updated r.stream order to the new version.
> In new version Horton and Hack do not require accum map. It use the
> longest stream length (calculated internally) to determine both Hack
> and Horton. But accum it is still leave as an option. So now Hack
> stream order indicate the longest (previously most accumulated)
> stream in the catchment. Due to the module do not require to read
> huge accum maps for horton and hack orders it works almost twice
> faster than previously.
> I also added r.stream.del (see more in description) but its
> functionality  is now integrated with r.stream.extract so I add it
> only as an option for r.watershed. It will be probably depreciated
> in the future.
> regards
> Jarek Jasiewicz
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
