[GRASS-user] Stuck Getting Started -- FIXED
Rich Shepard rshepard at appl-ecosys.com
Fri Nov 13 18:35:06 EST 2009
On Fri, 13 Nov 2009, Paul Kelly wrote:
> Sorry don't think I was clear enough - any branch, tag or version that you
> update from SVN at this moment in time will show revision 39721, as that
> is simply the latest change to have been made anywhere in the entire SVN
> tree.
Paul,
   The latest code fixed the problem. Using the wxPython UI I was able to
specify the data base and name the location and map set. Entering the
projection information went well, except there is no widget to enter units.
That bit me running r.in.gdal from within the GUI. That's another thread.
Many thanks,
Rich
