[GRASS-user] r.stream.extract - stream dir map output
Jarosław Jasiewicz jarekj at amu.edu.pl
Mon Nov 16 09:52:18 EST 2009
M S pisze:
> As an output from r.streams.extract, I'm getting a stream direction
> map that is only along the stream network, and null everywhere else.
> >From the manual, it seems the direction map needs to be for the entire
> study area.  I am looking to feed the streams and direction map into
> the r.stream.basins module.
> Since I'm on GRASS 6.4RC5, I dont have MFD option in my r.watershed,
> so I rely upon r.stream extract to output the stream network and the
> direction map.  I had seen a portion in the notes stating "Nowadays f
> direction map comes from r.stream.extract must be patched by direction
> map from r.watershed. (with r.patch).
> I wouldnt think I could patch the SFD direction output from
> r.watershed with the MFD stream direction map to create a direction
> map for the entire study area.  Is there another solution to use MFD?
if grass64 really do not have MFD (i'm suprised!) the only solution is
to compile grass 65 from source
Jarek
> Thanks,
> Mark
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
