[GRASS-user] matlab scripts r.dominant_dir.m and r.calc_terraflow_dir.m
M S mseibel at gmail.com
Wed Nov 18 05:55:47 EST 2009
Thank you for the info.  I wound up installing GRASS65 and using MFD
in r.watershed.  I was looking to those scripts to use MFD in GRASS64.
So, in short, I'm good to go.
Much thanks,
Mark
On Wed, Nov 18, 2009 at 4:52 AM, Hamish <hamish_b at yahoo.com> wrote:
> Mark:
>> I'm looking to use the addon scripts r.dominant_dir.m and
>> r.calc_terraflow_dir.m, however, I have never used Matlab
>> or Freemat.
>> I looked around for some examples or documentation on how
>> to run these scripts for (in?) GRASS, but have not found anything
>> helpful.
>> Can someone point me to a good resource to learn about
>> this?
> I am not sure how useful those scripts are, they were mostly the result
> of me exploring some code. but who knows maybe you have a good use for
> them.
> Octave is another GPL'd matlab clone.
> without looking how they work I'd guess r.out.mat was used to save
> a .mat file which octave could then load. ?
> the .m script is run by typing the name without the .m from the matlab
> command prompt.
> if you are still stuck I can try to find a little time to document
> them better.
> Hamish
