[GRASS-user] accumulation map from directions map
Achim Kisseler ak7 at jupiter.uni-freiburg.de
Thu Nov 19 07:46:16 EST 2009
Thanks, Jaroslaw for response,
> there shoud be no problem if you have oryginal DEM
I know, but I do NOT have the DEM. Thats the problem.
Achim
Jarosław Jasiewicz schrieb:
> Achim Kisseler pisze:
>> Hello again,
>> I am still searching a method to generate a flow accumulation map from a
>> flow direction map.
>> I got the direction map from an arcgis user. In arcgis the module
>> "FLOWACCUMULATION(FLOW_DIR)" would do this, but I want to use an open
>> source solution.
>> If anyone could give me a hint, where I could find a tool like this
>> (inside GRASS it does not seem to be possible), I would be very grateful.
>> Best regards,
>> Achim
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
