[GRASS-user] time dependent variable
Carbonari, Katie (IS) Katie.Carbonari at ngc.com
Thu Nov 19 16:16:47 EST 2009
I'm not so interested in making a movie; I want to be able to explore different layers of my maps as I see the data progresses. From the wiki page, there doesn't appear to be a way to do this, though.
Thanks,
Katie
-----Original Message-----
Sent: Thu 11/19/2009 1:35 AM
To: Carbonari, Katie (IS)
Cc: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] time dependent variable
Carbonari, Katie (IS) wrote:
> Hello. I have a netcdf file that I'm visualizing in GRASS. I first
> convert the parameters to GeoTiffs (using gdal_translate) and then
> incorporate into GRASS via r.in.gdal. Each file has 48 time steps (one
> per hour for 2 days). Is there any way to show the progression of my
> data in GRASS? I want to show which schools (or other such data) is
> affected by the path of my data (in this case, smoke from a fire). Any
> have any pointers?
If you're interested in making animations then on the GRASS wiki [1]
there are several suggestions.
One of the options is exporting the maps as png files then running a
tool called gifsicle to combine them into an animated gif. I've used
this [2] to make nice animated maps.
Micha
[1] http://grass.osgeo.org/wiki/Movies
[2]  http://my.arava.co.il/~micha/blog/?p=168
> Thanks,
> Katie
> This mail was received via Mail-SeCure System.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091119/2b1fb33b/attachment.html
