[GRASS-user] g.region Options Yield Different Values -- RESOLVED
Rich Shepard rshepard at appl-ecosys.com
Tue Nov 24 14:00:46 EST 2009
On Tue, 24 Nov 2009, Rich Shepard wrote:
> If I correctly understand what you wrote above, I use the projection
> information when importing the data, but leave the bounds undefined. Once
> the import is completed I can then run 'g.region rast=elevation10' to set
> the bounds in appropriate units.
   This is working very well. Only with the US Census TIGER street layer do I
have lat/long values in the result of 'g.region vect=streets'. I'll
reproject that into LCC and all layers should then be consistent.
Thanks,
Rich
