[GRASS-user] Reprojecting Vector Map
Pablo Carreira pablotcarreira at hotmail.com
Tue Nov 24 15:29:15 EST 2009
Hi Rich,
I have a general theory that may help you:
Assumptions:
-Very well defined LOCATION parameters is the foundation to perfectly combine maps of different sources.
-The experience tells me that some data are even in the correct reference system, but sometimes the "info" that comes with it sometimes not.
-Each coutry has it's adequated reference system.
-GIS and GPS comes with a lot of reference systems, but they follow an international standard.
-Those standards sometimes differ a little from the "real parameters".
What I do:
-I always take control of my LOCATIONS by methodically defining all the parameters with proj.4 sentences before starting a job.
-Some location is a "receptacle" for data.
-One location is for the work.
Pablo Torres Carreira
> Date: Tue, 24 Nov 2009 11:53:22 -0800
> From: rshepard at appl-ecosys.com
> To: grass-users at lists.osgeo.org
> Subject: Re: [GRASS-user] Reprojecting Vector Map
> CC:
> On Tue, 24 Nov 2009, Rich Shepard wrote:
> >  True. I completely forgot about this. With a new location/mapset I can
> > now use v.proj to move it over.
>    I'm still missing something. Defined a new location (streetsLCC) and
> mapset (rbs). Ran the following command successfully:
> GRASS 6.4.0svn (streetsLCC):/usr4/grassbase > v.proj input=streets
> location=streets mapset=rbs output=streets --verbose
>    'g.region -p' still shows lat/long after specifying 'g.region
> vect=streets
> GRASS 6.4.0svn (streetsLCC):/usr4/grassbase > g.region vect=streets
> GRASS 6.4.0svn (streetsLCC):/usr4/grassbase > g.region -p
> projection: 99 (Lambert Conformal Conic)
> zone:       0
> datum:      nad83
> ellipsoid:  grs80
> north:      45.46163298
> south:      44.88493498
> west:       -122.868113
> east:       -121.651714
> nsres:      0.576698
> ewres:      1.216399
> rows:       1
> cols:       1
> cells:      1
>    So I've not reprojected from LL to LCC at all.
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
_________________________________________________________________
Novo windowslive.com.br. Descubra como juntar a galera com os produtos Windows Live.
http://www.windowslive.com.br/?ocid=WindowsLive09_MSN_Hotmail_Tagline_out09
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091124/d92226cc/attachment.html
