[GRASS-user] Importing Converted Points File
Rich Shepard rshepard at appl-ecosys.com
Sat Nov 28 16:12:29 EST 2009
On Sat, 28 Nov 2009, Markus Neteler wrote:
> No, that's defined via "column" parameter (like this you can define names
> which differ from the first line [if present]).
Markus,
   That does clear it all up. Instead of having 'longitude|latitude|name' in
the header line I specify those (along with the data type) in the 'columns'
paramter.
Thank you,
Rich
