[GRASS-user] v.rast.stats script in windows distribution
francesco francesco.pirotti at unipd.it
Tue Sep 8 01:55:55 EDT 2009
This might help someone who is trying to run the v.rast.stats
(univariate statistics of raster values inside a vector area) in the
GRASS 6.4 windows distribution.
If the error message which appears when running v.rast.stats is "Cannot
continue (problem adding columns)" it might be due to the v.db.addcol
module not being correctly accessed by the script because it looks for
it in the bin directory where it only finds the v.rast.stats.bat file
(developers can correct me if I am wrong!). You can solve this by
copying the v.db.addcol script that you find in the script directory in
the bin directory. It worked for me, of course it is only a hack.
Cheers!
*Francesco Pirotti*
Dep. TESAF
CIRGEO – Interdepartmental Research Center on Cartography Photogrammetry
Remote Sensing and G.I.S.
University of Padova
Web: http://www.cirgeo.unipd.it/cirgeo/francescopirotti.htm
Email: francesco.pirotti at unipd.it <mailto:jdohn at freeemailtutorials.com>
Phone: +39 049 827 2710
