[GRASS-user] Krige surfaces in grass 6.4
kgb me at burlinson.id.au
Thu Sep 10 03:47:52 EDT 2009
Markus and list readers
>>> V.krige.py, requires gstat built with grass support,
Markus Neteler replied:
> This is not clear to me. I have used this new module and
> it requires a gstat installation within R, so in my experience it
> did not need to compile gstat with GRASS support but just
> installed the gstat-R extension.
> Perhaps you could try that?
Markus.  I do have R installed and it works. I also installed R2py and I thought it worked
as it did not report errors.
But r2py is a strange package. Many of the test programs in the package fail and the
website says 3 of them will fail, but not which 3! I can only assume the installation is
faulty and the r2py website lacks information to resolve the problem. Even their demo
program code on their website is broken. But after repairing the syntax faults, I am
having object access issues with their demo and I think r2py has failed to build properly.
despite having R and r2py (albeit perhaps broken) installed, grass gives me this error
about gstat requirements when I run v.krige.py
GRASS 6.4.0RC5 > v.krige.py
Warning message:
In library(package, lib.loc = lib.loc, character.only = TRUE, logical.return = TRUE,  :
  there is no package called 'gstat'
R package gstat is missing. Install it and re-run v.krige.
But as commented to Hamish, there are library problems which prevent me from building
gstat with grass library support or building it as a library, even without grass support.
> But: there is a backport missing of some wxPython feature so
> it may be possible that for the GUI version only GRASS 6.5 or
> later works.
... that is interesting - but i cannot even get a clean build of wxPython from the current
tarball. That problem is not with grass - possibly my gcc version!
Kingsley
