[GRASS-user] Dsn error in Window$
Vincent Blanqué vincent.blanque at oriondata.cl
Thu Sep 17 11:51:46 EDT 2009
@emmanuel:
v.out.ogr -e input=hidro3D at PERMANENT dsn=C:/tmp/hidro3D
(Thu Sep 17 11:48:08 2009) Command finished (1 sec)
But I get a Window$ bug: "v.out.ogr.exe" has stopped to work.
@kapo:
v.out.ogr -e input=hidro3D at PERMANENT dsn=C:/tmp/ olayer=hidro3D
ERROR 1: Failed to create directory C:/tmp/
for shapefile datastore.
Thanks, both solutions does not work, I will get rid of Window$ !!!
kapo coulibaly a écrit :
> Or you can add a name for the output file this way:
> 2009/9/17 maning sambale <emmanuel.sambale at gmail.com>
>> afaik,
>> it should be:
>> On 9/17/09, Vincent Blanqué <vincent.blanque at oriondata.cl> wrote:
>>> Hi,
>>> It's my first post here. I am quite happy to join the powerful world of
>>> GRASS. My first good impression is with the 'v.drape' process.
>>> With the 'v.out.ogr' command, I get an issue with the dsn parameter.
>>> I tried various syntax for dsn "path & filename" but none works fine.
>>> v.out.ogr -e --verbose input=hidro3D at PERMANENT dsn=C:/tmp/hidro3D.shp
>>> v.out.ogr -e --verbose input=hidro3D at PERMANENT dsn="C:/tmp/hidro3D.shp"
>>> ERROR 1: Failed to create directory "C:/tmp/hidro3D.shp"
>>> v.out.ogr -e input=hidro3D at PERMANENT dsn=/c/tmp/hidro3D.shp
>>> I am using GRASS 6.4.0svn (2009) - Revision: 37101 in Windows Vista
>>> (very bad choice).
>>> Do you know what happens ?
>>> In Linux Ubuntu, everything is great.
>>> see U,
>>> Vincent
>> cheers,
>> maning
>> "Freedom is still the most radical idea of all" -N.Branden
>> wiki: http://esambale.wikispaces.com/
>> blog: http://epsg4253.wordpress.com/
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090917/6f380815/vincent_blanque.vcf
