[GRASS-user] Re: Exporting attributes to GMT ASCII format using v.out.ogr
Markus Metz markus.metz.giswork at googlemail.com
Thu Sep 24 03:42:57 EDT 2009
Benjamin Ducke wrote:
> IMHO choosing line/boundary as a default for ANY map
> (i.e. even one that has no such geometries) is a bug,
> not useful default behaviour.
> So I would expect any scripts that use v.out.ogr in earnest
> to be setting the type= option explicitly, anyhow.
IMHO, that applies to many vector modules. Having as default answer for
the type option all types can produce unexpected and undesired results.
The user would want a module to act only on certain types, but it is
easy to forget setting the type option accordingly and then all vector
object types are processed. Rather have the type option not set at all
by default and exit with an error if no type is selected?
Markus M
> The problem reported earlier with exporting areas
> to GMT format seems to me to illustrate this.
> The relationship between lines, boundaries and areas
> can be very confusing, especially when data export/import
> is concerned.
> Actually, I would like to improve the area export logics
> so that problems like Eric experienced will get more rare
> in the future.
> Anyhow, if there is a consensus that the old default
> behaviour needs to stay, I will change the automatic
> export type determination to only run on user demand,
> via a flag.
> Cheers,
> Ben
> ----- Original Message -----
> From: "Hamish" <hamish_b at yahoo.com>
> To: "Eric Patton" <epatton at nrcan.gc.ca>
> Cc: "grass-user" <grass-user at lists.osgeo.org>, "Hermann Peifer" <peifer at gmx.eu>
> Sent: Monday, September 21, 2009 9:35:49 PM GMT +01:00 Amsterdam / Berlin / Bern / Rome / Stockholm / Vienna
> Subject: [GRASS-user] Re: Exporting attributes to GMT ASCII format using v.out.ogr
> Hamish:
>>> I would ask if it acts any differently in latest grass
>>> 6.5 or 7 svn builds? (6.5 change may be reverted as it may
>>> break backwards compatibility / expected behaviour)
> Eric:
>> Which change are you referring to? I'm using the latest
>> 6.5.svn, and all seems to run smoothly.
> make that "in new cases make things better, but subtly break backwards compatibility / expected behaviour in existing scripts."
> ie an old script for 6.x should produce the same output as a new script at the cost of the default action not being as nice.
> I don't really know if this is just hypothetical or if it could really screw somebody up. (ie if it matters or not)
> r39128
> https://trac.osgeo.org/grass/log/grass/branches/develbranch_6/vector/v.out.ogr
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
