[GRASS-user] Re: r.stream.order problem making on mac os x
William Kyngesburye woklist at kyngchaos.com
Sun Sep 27 18:43:47 EDT 2009
Is that all the binary images lines?  If so, then somehow compilation
didn't link the GRASS libraries.
There are no changes listed in grass-addons SVN after it was added, so
I can't tell if something changed in the Makefile since it last worked
for you.
On Sep 27, 2009, at 5:23 PM, stephen sefick wrote:
> Is this what you were talking about?  If it is not I can find it if
> you tell me what I am looking for.
> Process:         r.stream.order [73041]
> Path:            /Applications/GRASS-6.4.app/Contents/MacOS/bin/
> r.stream.order
> Identifier:      r.stream.order
> 2   r.stream.order                	0x0000213e write_maps + 46
> 3   r.stream.order                	0x00002b71 main + 897
> 4   r.stream.order                	0x00001a56 start + 54
>    0x1000 -     0x3fff +r.stream.order ??? (???)
> <7ba7322bd390054caeff9595a09fd4d0>
> /Applications/GRASS-6.4.app/Contents/MacOS/bin/r.stream.order
> On Sun, Sep 27, 2009 at 4:37 PM, William Kyngesburye
> <woklist at kyngchaos.com> wrote:
>> There should be a crash log for r.stream.order, which you can find
>> in your
>> home logs with Console.app.  The trace is especialy useful, though
>> the
>> binary images info can be helpful.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
