[GRASS-user] Database driver problem
grassyjohn jf_walsh at hotmail.com
Mon Sep 28 17:30:46 EDT 2009
Hamish wrote:
if you use the latest native windows installer the patch should already
be applied. (WinGRASS-6.4.0SVN-r39271-1-Setup.exe   21 Sept 2009)
if you are using that version and it still breaks, we'd like to hear
about it.
I did use the latest installer on XP.  If I am importing ESRI files and the
corresponding dbf file, does it matter where I put them as long as I select
the correct paths to the files in the dialogs?
grass-user mailing list
grass-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/Database-driver-problem-tp3720138p3732043.html
Sent from the Grass - Users mailing list archive at Nabble.com.
