[GRASS-user] starspan with grass support compilation failure
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Tue Sep 29 06:45:45 EDT 2009
On Tue, 2009-09-29 at 10:09 +0200, Xavier Delaunay wrote:
> Dear Nikos,
> I had the same compilation error when compiling Starspan, although I am
> not using GRASS. I googled the error message and I found your post.
> I also find clues here:
> https://safe.nrao.edu/wiki/bin/view/GB/Knowledge/Gcc3Compatibility?sortcol=table;up=#3_3_STL_iterators_are_not_pointe
> And there:
> http://www.cplusplus.com/reference/algorithm/
> So my solution has been to add the following line at the beginning of
> the source file src/stats/Stats.cc
> #include <algorithm>
> This works in my case.
> Hope this helps.
> I am not using the GRASS mailing list, so you can post this solution if
> it works in your case.
> Best regards,
[cc-ing to grass-user ML]
Many many thanks Xavier :-)
Indeed, it works. I could never find this since I am an (almost
complete) ignorant wrt to C. Hope this helps others as well.
Kindest regards, Nikos
